Feature Requests
Scaling Fix with Overlay Tab
I have a regular problem with the location of the overlay tab on the bottom tool bar. I use an MS Surface for presentations. It's also easier to build the Vmix setup on the Surface because that is what I'll be using for the presentation. I have a regular problem because the recommending screen scaling is relatively large. The result is that the overlay tab at the bottom is missing entirely. The only way to correct this is to reduce the scaling, but that means that the font becomes exceptionally small. I would like to suggest either: 1. Move the overlay tab into a stack on the left side of the screen. Because it's on the right side, it gets cut off when the scaling is increased. This could be accomplished by either moving the other tabs side-by-side and adding the overlay to that stack, or by just moving the overlay tab to the left. 2. Allow the user to customize the bottom tool bar and choose which tabs are shown. Because I only use Vmix for presentation, I don't need some of the existing tabs. Thanks for reading and creating such a great product!
Feature Requests
