Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
I just checked and in vMix 24 beta there is ReplayDeleteSelectedEvent and ReplayDeleteLastEvent.
Joined: 5/16/2020(UTC) Posts: 38  Location: Trondheim Thanks: 2 times
Still hoping for a delete all replays shortcut.
Joined: 5/10/2022(UTC) Posts: 15  Location: Brisbane Thanks: 1 times
Originally Posted by: Barney Box Lane  a shortcut for instantly deleting a replay without confirmation +1
Joined: 12/8/2022(UTC) Posts: 168  Thanks: 52 times Was thanked: 3 time(s) in 3 post(s)
Please add shortcuts for deleting the entire list of replay events and multiple selected events. (I tried selecting multiple events and used the ReplayDeleteSelectedEvent but it only deleted one event). In the interface you can select multiple events, right click and choose "remove" to delete them but there is no shortcut for this.
So I miss these two shortcuts:
ReplayDeleteSelectedEvents ReplayDeleteAllEvents
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
bumping this request as it's had a lot of support (unless I've missed it being implemented)
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: Barney Box Lane  unless I've missed it being implemented Yes, vMix 24. ;-) ReplayDeleteLastEvent ReplayDeleteSelectedEvent
 1 user thanked dmwkr for this useful post.
Joined: 1/17/2023(UTC) Posts: 14  Location: Denver Was thanked: 1 time(s) in 1 post(s)
Is there a way to delete "sessions" from Replay? This would be much better than relying on "delete oldest when disk is full"
In my workflow I start Replay recording at the beginning of a match and stop it at the end of the match. Then at the end of the tournament ill go through the events to built a highlight reel. However I don't want/need events from matches that did not result in a win.
ah brilliant thank you dmwkr
Originally Posted by: TL68  Please add shortcuts for deleting the entire list of replay events and multiple selected events. (I tried selecting multiple events and used the ReplayDeleteSelectedEvent but it only deleted one event). In the interface you can select multiple events, right click and choose "remove" to delete them but there is no shortcut for this.
ReplayDeleteSelectedEvents ReplayDeleteAllEvents +1 If you are trying to use the replay event workflow and do it without using the mouse, the tabs come in handy to filter events you might want to replay at once, like highlights from a single skater, a scoring drive or a power play, etc. To keep the workflow to as few shortcuts as possible, the possibility to delete the events from a tab to re-fill it again, would be very helpful.
