Feature Requests
Shortcut to change Replay stinger
I would like to be able to change stinger in/out transition for replays using a shortcut. This would enable the ability to have different stingers for different types of replays, for example showing in game instant replays and showing replays as highlights.
Joined: 3/3/2021(UTC) Posts: 32   Location: São Paulo Thanks: 1 times Was thanked: 12 time(s) in 5 post(s)
Joined: 2/14/2020(UTC) Posts: 29  Location: Brisbane Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
It would be enough if you could just pick one of the pre defined transitions that are in the drop down in the replay settings. Then I could have Stinger 1 set up for normal instant replays and Stinger 2 for highlights and so on.
Rank:: Advanced Member
Joined: 4/23/2017(UTC) Posts: 1,478  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 14 time(s) in 9 post(s)
A chance to implement this shortcut in v26?
Joined: 7/1/2020(UTC) Posts: 104  Location: Earth Was thanked: 23 time(s) in 20 post(s)
For those of us needing more than 4 stinger transitions, adding shortcuts to change the Stinger parameters (type, effect, duration, input, cut point) would be most useful. Then we could build shortcut stacks to change what Stinger1 does and have as many stinger looks as we want.
Feature Requests
