hakan_forss
#1 Posted : Monday, April 11, 2022 6:46:08 AM(UTC)
hakan_forss
Sweden
It would be very useful to be able trigger a function or run script based on the DataChangeIn/Out event in the GT Title. Add the option to add vMix scripts in the GT Title it self or a trigger on the input the title is loaded in.
This would be very useful to build more advanced scoreboards and increase automation based on outside data sources
#2 Posted : Monday, April 11, 2022 7:57:39 AM(UTC)
for the ability to process data in a title one can revert to legacy XAML (WPF) title with code behind. then all is build into the title itself, less hastle in setups later. (actions based on changes, values, formulas, score rules checking, triggering animations, image selections on changes or status etc). Also not limted in use to 4k and above. just load the title and tie to data or edit and be done
Want to stick to GT titles, just have a 1 running script check for changes and act accordingly (within the available posibilities of the graphics options).
Not a bad request for simple things but imo could become very complex and maintain oversight of the triggers and various scripts in case of real complex score and its rules processing (if at all even possible to achieve the same as with aan XAML title)
Have looked in transfering our scoring titles into scripting and GT titles and so far always hit a limitation (or more hasstle and error prone) versus our current ones (vMix scripting is very linear)
Mr. Broadcast
#3 Posted : Tuesday, May 10, 2022 9:10:48 PM(UTC)
Mr. Broadcast
+1+1
