daveydouble
#1 Posted : Saturday, April 9, 2022 5:59:04 PM(UTC)
daveydouble
Feature Request:
Option to seperate Busses A-G to seperate Mono Busses, available as NDI and/or Dante with stereo audio automatically collapsed to Mono.
- Enables MixMinus audio to be output to individual audio bus, to be delivered over NDI Audio Only to seperate systems (such as Zoom) without use of Virtual Audio cables.
Expose Input Audio FX to API to enable programming of audio control surfaces (Behringer XTouch Compact, Mini etc) as 'Channel Strip' controllers on a 'Selected Channel'
- Enables operation to be programmed in closer to a digital audio desk; Gain, EQ (graphic or parametric), Compression, Gate and Delay should all be available to an audio engineer on a 'selected channel' basis, which is a standard workflow for audio operators on digital desks.
Bus A-G assignment button visible on Mixer
VU Meter visible on collapsed channels
VU Meter standard clearly labelled on meters (dBFS or dBVU)
Option for MASTER Bus on Right of Mixer
