Joined: 4/22/2019(UTC) Posts: 8  Location: BUCURESTI Thanks: 1 times
Is there a way to rename a file on the computer with vMix script using the text from a title as the new name?
Thank you!
Originally Posted by: FlorinU  Is there a way to rename a file on the computer with vMix script using the text from a title as the new name?
Thank you! Yes. a forum search willl do it, hint "modify record Filename"
