NicholasBates
#1 Posted : Thursday, April 7, 2022 5:13:58 PM(UTC)
NicholasBates
I cant see where to go from here?
Hey man,
Cant get the code to work, can i get your assistance?
Starting Script "Timestamp"
Script 'Timestamp' Error Line 8: Object reference not set to an instance of an object.
Stopping Script "Timestamp"
Originally Posted by: elgarf Go to Quoted Post
You can use script if you have 4K or Pro version.
Code:
'Text file for time marks
dim FILENAME = "D:\out.txt"
'Get recording duration
dim xml = API.XML()
x.loadxml(xml)
dim Duration = integer.parse((x.SelectSingleNode("//recording/@duration").Value))
dim Second = math.floor(Duration mod 60)
dim Minute = math.floor((Duration / 60) mod 60)
dim Hour = math.floor((Duration / (60 * 60)) mod 60)
'Write recording duration to file
System.IO.File.AppendAllText(filename, string.format("{0:00}:{1:00}:{2:00}"&Environment.NewLine, Hour, Minute, Second))
#2 Posted : Thursday, April 7, 2022 7:31:38 PM(UTC)
if you are going to keep posting the same question in different posts ( as you claim in the hope of getting an answer faster) without reading the answer given in one of them you run the risk of being banned from this forum for spamming
NicholasBates
#3 Posted : Thursday, April 7, 2022 7:46:47 PM(UTC)
NicholasBates
Its more about the title
gpdipalmerahtimur
#4 Posted : Thursday, April 7, 2022 8:26:19 PM(UTC)
gpdipalmerahtimur
Indonesia
Hi Nicholas,
You need to test the XML returned by vMix. As far as I remember we have "vmix" as root node, you can't find the other node if you don't use the root node. I suggest you to test it with Console.WriteLine and do some research from the Google. If it is related to VB.NET basic, I think we shouldn't ask here. Probably you can ask in this thread instead:
Scripting for Dummies
Doggy is expert in this :)
#5 Posted : Thursday, April 7, 2022 9:12:40 PM(UTC)
Originally Posted by: gpdipalmerahtimur Go to Quoted Post
Hi Nicholas,
OP should not be an ** by make several new duplicate posts about this and read the answer given where he originally asked the question
Can't find a node if it is not there ;-)
https://forums.vmix.com/posts/m101117-Timecode-Marker-Hotkey#post101117
that's 3 different posts : this one , the link above and this https://forums.vmix.com/posts/t28839-Cant-get-Code-to-work
