shawntempesta
#1 Posted : Friday, August 21, 2020 9:30:43 AM(UTC)
shawntempesta
Thanks Given:
Was thanked: 9 time(s) in 7 post(s)
I do a daily Facebook Live talk show, and I have moments that I ABSOLUTELY want to put in the recap video. But I forget where they are and have to hunt for them. I'd write them down if I didn't have to host the show on top of switch it.
What would be AWESOME is to have a hotkey we can set that, when you hit it, puts the time of recording in a TXT file. So when I go to edit, I can check the times I marked and find the clips I want.
Let it be done, vMix Gods.
#2 Posted : Friday, August 21, 2020 3:54:03 PM(UTC)
Something like WriteDurationToRecordingLog function ? If only there was
elgarf
#3 Posted : Friday, August 21, 2020 4:57:19 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
You can use script if you have 4K or Pro version.
Code:
'Text file for time marks
dim FILENAME = "D:\out.txt"
'Get recording duration
dim xml = API.XML()
x.loadxml(xml)
dim Duration = integer.parse((x.SelectSingleNode("//recording/@duration").Value))
dim Second = math.floor(Duration mod 60)
dim Minute = math.floor((Duration / 60) mod 60)
dim Hour = math.floor((Duration / (60 * 60)) mod 60)
'Write recording duration to file
System.IO.File.AppendAllText(filename, string.format("{0:00}:{1:00}:{2:00}"&Environment.NewLine, Hour, Minute, Second))
thanks 3 users thanked elgarf for this useful post.
doggy on 8/21/2020(UTC), AgentPete on 6/28/2022(UTC), Pothala on 11/24/2023(UTC)
#4 Posted : Friday, August 21, 2020 5:07:49 PM(UTC)
Hi elgarf
Mind adding it to the Dummies posts ?
elgarf
#5 Posted : Friday, August 21, 2020 6:04:18 PM(UTC)
elgarf
Russian Federation
No problem
thanks 1 user thanked elgarf for this useful post.
shawntempesta
#6 Posted : Sunday, August 23, 2020 7:29:07 PM(UTC)
shawntempesta
Thanks Given:
WHOA! If this is actually accomplishable now - I am beyond thrilled. And thank you @elgarf!
Threw it in - and wouldn't you freaking know it. WOW. You're a genius. THANK YOU SO MUCH.
NicholasBates
#7 Posted : Thursday, April 7, 2022 3:51:26 PM(UTC)
NicholasBates
I cant see where to go from here?
Hey man,
Cant get the code to work, can i get your assistance?
Starting Script "Timestamp"
Script 'Timestamp' Error Line 8: Object reference not set to an instance of an object.
Stopping Script "Timestamp"
Code:
dim xml = API.XML()
x.loadxml(xml)
#8 Posted : Thursday, April 7, 2022 4:26:55 PM(UTC)
Hey man,
Script wil be error free when actually recording ! (does not include a check for it)
usaiegh
#9 Posted : Monday, April 3, 2023 11:54:05 PM(UTC)
usaiegh
Argentina
Hi! Can i make it work with the multicorder instead of the normal recording option? Thx
#10 Posted : Tuesday, April 4, 2023 12:33:46 AM(UTC)
With a different approach one could by checking on the multiCorder status to start a clock reference and such or something like that
usaiegh
#11 Posted : Tuesday, April 4, 2023 12:57:49 AM(UTC)
usaiegh
Argentina
Do you know how can I get the multi corder values/status?
#12 Posted : Tuesday, April 4, 2023 1:22:22 AM(UTC)
https://forums.vmix.com/...ng-for-Dummies#post71124
with multiCorder instead
Pothala
#13 Posted : Friday, November 24, 2023 8:48:13 PM(UTC)
Pothala
Spain
Code:
dim xml = API.XML()
x.loadxml(xml)
Hello, I need a script that when executed takes the value of a counter located Time.Text in a title called timer.gtzip, and writes it to c:\time.txt, it's possible?
#14 Posted : Friday, November 24, 2023 9:35:11 PM(UTC)
Code:
dim xml = API.XML()
x.loadxml(xml)
Your question is NOT related to this thread!
It is possible
Check the "scripting for dummies" post were one can find examples of how to read from a title and how to write to a file
Second part of your question is shown s example in your post
