curiousgeorge
#1 Posted : Wednesday, April 6, 2022 5:48:32 PM(UTC)
curiousgeorge
Hey Peeps!
I am filming a course for web design, and I am pretending to be a videographer.
Does anyone know how to zoom in and zoom out with Vmix?
I have a pocket 4k and Atem Mini Pro and Atem Mini ISO.
I currently own the following lens, but I am not sure how they work:
CANON EF LENS 50MM
PANASONIC LUMIX G 25MM
ROKINON 85MM FULL FRAME CINE LENS
META BONES ADAPTER LENS
#2 Posted : Wednesday, April 6, 2022 5:55:20 PM(UTC)
https://www.vmix.com/help25/index.htm?InputSettingsPosition.html
curiousgeorge
#3 Posted : Wednesday, April 6, 2022 7:04:43 PM(UTC)
curiousgeorge
I meant to say, how to get a good long angle shot, with the camera? My BMM4K Pocket 4K camera seems looking up my nostrils, and I can't figure out how to zoom out? I don't have a big room.
Tone13
#4 Posted : Wednesday, April 6, 2022 8:00:30 PM(UTC)
Tone13
None of your lenses are zoom lenses. Move the camera and yourself further from each other?!
curiousgeorge
#5 Posted : Thursday, April 7, 2022 5:38:35 AM(UTC)
curiousgeorge
Can you suggest any zoom lens that works with BMM4k and zooms out in reverse?
Tone13
#6 Posted : Thursday, April 7, 2022 10:18:35 AM(UTC)
Tone13
Your camera has a Micro Four thirds sensor and mount. Good zoom lenses for this are the Panasonic 12-60 or any other MFT zoom lens that starts at 12mm . Basically, The first number (12mm) tells you how wide the lens is. The second (60mm) tells you how far it will zoom. Keeping it simple, without lens adaptors, Some good options are:
Panasonic 12-60
Panasonic 12-35
Panasonic 12-32
Panasonic 14-140
Olympus 9-18
Olympus 12-45
curiousgeorge
#7 Posted : Thursday, April 7, 2022 12:24:48 PM(UTC)
curiousgeorge
Panasonic 12-60
Panasonic 12-35
Panasonic 12-32
Panasonic 14-140
Olympus 9-18
Olympus 12-45
Can anyone send me the links affiliate links to Amazon? Im not sure exactly which ones to get and want to be sure...
Also, for my use case, which is 90% youtube videos in my bedroom, is this the best option? Does this integrate with black magic software so I can co trol zoom remotely?
curiousgeorge
#8 Posted : Sunday, April 10, 2022 3:57:36 PM(UTC)
curiousgeorge
Panasonic 12-60
Panasonic 12-35
Panasonic 12-32
Panasonic 14-140
Olympus 9-18
Olympus 12-45
THANK YOU SO MUCH!
