Feature Requests
Import Csv Title Preset Shortcuts
Joined: 10/22/2016(UTC) Posts: 25   Location: Lucca, Italy Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Sorry for my english...
Can add a shortcuts for import a csv file on a title?
Joined: 6/27/2021(UTC) Posts: 43   Thanks: 50 times Was thanked: 4 time(s) in 4 post(s)
What is it that you're trying to do?
Che cosa stai cercando di fare?
Thanks for your concern.
I created a script with which I load m3u playlists (created by a third software) to populate some input lists. I also have inputs as a title to broadcast photos (resized with the right aspect ratio), which can only be populated with a CSV file and not with an M3U list.
Thanks for your help!
Yes, i know. But you can't use for this.
Because we are a local tv station and when we are on live we have to do fast, and we can open data source for see the selected row. And i am not the only user of vMix, and it's hard explain at all how it's work.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: meremultimedia  Because we are a local tv station and when we are on live we have to do fast Is that relevant? We all want to operate fast and efficiently Quote:and we can open data source for see the selected row. And i am not the only user of vMix, - one can have a duplicate title with the other data source or csv presets - A data source manager can be kept open , even on another monitor for quick row selection or other - thinking outside the box often helps with the tools available , data can be read and and manipulated using vMix scripts or external scripts giving selection options Quote: and it's hard explain at all how it's work. Understand, which makes it hard to give proper answers
Quote: - one can have a duplicate title with the other data source or csv presets - A data source manager can be kept open , even on another monitor for quick row selection or other - thinking outside the box often helps with the tools available , data can be read and and manipulated using vMix scripts or external scripts giving selection options
Thanks for the solution. Not everyone is at the same level of knowledge of the various software, I think that asking for help on this forum is just to learn new things and give advice on functions that may not be implemented yet.
 1 user thanked meremultimedia for this useful post.
Originally Posted by: meremultimedia  advice on functions that may not be implemented yet.
vMix is so flexible and customizable often another solution can be found within, is why it so usefull in many types of productions.
I'm going to try again, from the top ^_^ Originally Posted by: meremultimedia  Can add a shortcuts for import a csv file on a title? [...]we have to do fast, and we can open data source for see the selected row. If you have the CSV loaded and there are changes to it, vMix picks up immediately. Like if you have a title in preview that says "Josh sucks" because that row is selected from the CSV, and you update the CSV outside of vMix to say "Josh rules" that change will happen in vMix without you doing anything. I hope this helps!
Feature Requests
