MSFTGuruGuy
#1 Posted : Friday, April 1, 2022 5:58:08 AM(UTC)
MSFTGuruGuy
Early in VMIX 24 when I would import multiple NDI feeds using Microsoft TEAMS, I would get audio sources from each of the inputs in the mixer, but all the NDI audio sources would be heard in each input. Because there would be slight (1ms) delays between the sources I would hear what amounts to reverb across all the channels unless I muted all the NDI audio sources but one. Later in 24 that seemed to change and the audio sources matched the NDI input where one could mute one and it not it not be heard in others as a traditional mixer. In v.25 I'm seeing this full muxing again, I have updated to NDI tools 5 but wondering if this is something that was addressed in 24 or something new in 25 before I go and start to change versions of Vmix to try to isolate the problem I'm seeing. Ideas?
VMIX 25.0.0.29, Intel i9 10th Gen, 128GB RAM, NVIDIA 3090, Windows 11
Kris
MSFTGuruGuy
#2 Posted : Friday, April 1, 2022 2:48:12 PM(UTC)
MSFTGuruGuy
I can confirm returning to 25.0.0.24 resolves this issue and probably the issue in the other post with similar NDI issue in MS TEAMS.
jkarshner
#3 Posted : Saturday, April 2, 2022 12:22:03 AM(UTC)
jkarshner
Yes, This is the same issue I had. Does anyone know how to revert to 25.0.0.24?
MSFTGuruGuy
#4 Posted : Saturday, April 2, 2022 3:02:50 AM(UTC)
MSFTGuruGuy
The installers for the previous version are in the My Documents folder on Windows OS's. I downgraded in place, Though I'm sure that's not supported well.
