Joined: 4/13/2021(UTC) Posts: 15  Location: Düsseldorf
Hi! Maybe someone can help me to modify batch file and script? its working but its keep trying to reopen Vmix and loop commands. The purpose is as follows: -After 5 seconds of Close or Crash, Vmix restarts and after 10 seconds from lunch start to stream
Batch file in startup:
ECHO Start vMix :VMIX start "" "C:\Users\Admin\AppData\Roaming\last.vmix echo (%time%) Streaming started. PING 127.0.0.1 -n 10> NULL ECHO Start Streaming start "" "D:\vmix\stream.vbs" echo (%time%) WARNING: VMIX closed or crashed, restarting. :: Wait 5 seconds before restarting. TIMEOUT /T 5 GOTO VMIX
Stream.vbs:
On Error Resume Next
Dim o Set o = CreateObject("MSXML2.XMLHTTP") o.open "GET", "http://localhost:8088/api/?Function=StartStreaming", False o.send
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: Suhil  Hi! Maybe someone can help me to modify batch file and script? its working but its keep trying to reopen Vmix and loop commands. The purpose is as follows: -After 5 seconds of Close or Crash, Vmix restarts and after 10 seconds from lunch start to stream
Stream.vbs:
Hi Bro , first of all good job ! nice script! but it can be done so easily , just by vmix itself web api ! look at this : timeout 60 start http://localhost:8088/api?function=StartPlayList timeout 10 start http://localhost:8088/api?function=StartStreaming put the batch file and a shortcut from your last.vmix file into windows startup shell:startup
