DavidG
#1 Posted : Wednesday, March 30, 2022 6:17:26 AM(UTC)
DavidG
Losing frames or sync between Roland V1-HD and Magewell Pro capture 4k in an I-7 PC with GeForce RTX 3060 w 3GB - all drivers fully updated. Roland embeds audio and outputs 1080p video. Sync/frame problem started after both VMIX and Windows were updated. Therefore I suspect a problem with VMIX and Windows. Strange thing is while streaming there are No error messages or video frames lost, BUT Audio skipping can be heard on computer output. When viewing after stream, full video frames can be seen lost. Should I revert back Windows or VMIX ?
DavidG
#2 Posted: : Monday, April 4, 2022 8:50:26 AM(UTC)
DavidG
Well thanks for all your help :( . Turns out the weird default for "Video In" while "adding a camera", is PAL. Nothing against it, and BTW VMIX does a great job of trying to make it work, but PAL does not work here in the states. I emailed this question directly to Support guys, usually get a quick response, but Nothing this time... gone are the days...
