Can't save preset throught API without confirmation
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 756
hi,
i want to save my preset throught API but it asks me for a confirmation or preset is not saved when i already have a preset file on a specyfic folder.
this is only on fresh install of v25, v24 worked well.
this is only on fresh install of v25, v24 worked well. hmm, can confirm that it does save without asking for filename if filename is specified in the function/shortcut . An exisitng preset file with same location/name is updated (but not its file date/time though)
Rank: Guest
update: i founded some interesting things dealing with this...
*even a filename is specified, the API always ask for location; *i add a trigger on list settings, 10000ms delay, to save preset specifying filename, preset is saved without ask for location. this method changed Modification Date only, Creation date remains the same on the file.
so, i think this little "issue" only take the API
