DThompson55
#1 Posted : Tuesday, March 29, 2022 6:31:15 AM(UTC)
DThompson55
Still new, still learning... Here's what I want to do: I have short cut A that brings up an asset/video. Short cut B brings up an overlay. I want to automate this somehow so with one key press it effectively does shortcut A, waits 4 seconds, does shortcut B. I'm fairly certain you can string things together like this, but not sure what this would be called in VMix or where to look in the manual. Or if VMix does this out of the box or if I have to script it?
SportsNetUSA.net
#2 Posted : Tuesday, March 29, 2022 8:38:28 AM(UTC)
SportsNetUSA.net
https://www.vmix.com/help24/inde...m?MultipleShortcuts.html
Also you can use Add Shortcut -> Advanced
thanks 1 user thanked SportsNetUSA.net for this useful post.
DThompson55 on 3/29/2022(UTC)
mavik
#3 Posted : Tuesday, March 29, 2022 11:32:45 PM(UTC)
mavik
Some task can be done with triggers as well. Might be a bit more elegant if you delay the title by a second or so if the new source gets online.
DThompson55 on 3/30/2022(UTC)
