switch input source automatically
Joined: 8/3/2021(UTC) Posts: 13   Location: Weihai Thanks: 4 times
When I use vMix to stream some broadcasting, I get in trouble with the lost of signal. So I wanna to realize the funcation of switching input source automatically to an alternative input source, and switching back when the singnal comes back. I think it'll be possible via script, but I failed. Can somebody please help me to solve the problem? I cannot find any hint from the forum, perhaps I ran the wrong way.
Please help me, this really confused me for a loooooong time.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: doggy  Thank you very much! But the program I am broadcasting is mute all the time, actually it is ISS live broadcasting. So I cannot realize this function by voice detection. And the most reliable way I think is the recognition of the pause screen.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
Where is the feed coming? RTMP, Stream, SDI, etc? What is the LOS method, signal cutoff, black video etc?
 1 user thanked MartLeib for this useful post.
Originally Posted by: Haifeng  And the most reliable way I think is the recognition of the pause screen. Its possible by means of some code to compare images (snapshots) easy enough if they are exact match (pixel based) say when frame is frozen (or equal to a reference image) .net code, autohotkey(screenregion) even etc
Originally Posted by: MartLeib  Where is the feed coming? RTMP, Stream, SDI, etc? What is the LOS method, signal cutoff, black video etc? I get the video source by adding web-browser,and the pause screen shows below.  Wei Xin Tu Pian _20220324122802.png (1,512kb) downloaded 0 time(s).And also there is a almost total black screen when ISS run to the night part.  Wei Xin Tu Pian _20220324122807.png (811kb) downloaded 0 time(s).Thank you for your attention.
Originally Posted by: doggy  Originally Posted by: Haifeng  And the most reliable way I think is the recognition of the pause screen. Its possible by means of some code to compare images (snapshots) easy enough if they are exact match (pixel based) say when frame is frozen (or equal to a reference image) .net code, autohotkey(screenregion) even etc Yep, I think so, but I have no idear about the composition of scripts. By the way,the pause screen isn't stable, it flickers. Thank you for your reply!
Originally Posted by: Haifeng  Originally Posted by: doggy  Originally Posted by: Haifeng  And the most reliable way I think is the recognition of the pause screen. Its possible by means of some code to compare images (snapshots) easy enough if they are exact match (pixel based) say when frame is frozen (or equal to a reference image) .net code, autohotkey(screenregion) even etc Yep, I think so, but I have no idear about the composition of scripts. By the way,the pause screen isn't stable, it flickers. Thank you for your reply! You initially asked for when you lost signal but this is totally not the case as you are still having signal jus not the footage you want you are highjacking. Even then there is no consistency in the image you want to trigger on to be able to compare image effectivly. Might try a compare on the first image for match and add a time table to act on for when its in night position
Originally Posted by: doggy  Originally Posted by: Haifeng  Originally Posted by: doggy  Originally Posted by: Haifeng  And the most reliable way I think is the recognition of the pause screen. Its possible by means of some code to compare images (snapshots) easy enough if they are exact match (pixel based) say when frame is frozen (or equal to a reference image) .net code, autohotkey(screenregion) even etc Yep, I think so, but I have no idear about the composition of scripts. By the way,the pause screen isn't stable, it flickers. Thank you for your reply! You initially asked for when you lost signal but this is totally not the case as you are still having signal jus not the footage you want you are highjacking. Even then there is no consistency in the image you want to trigger on to be able to compare image effectivly. Might try a compare on the first image for match and add a time table to act on for when its in night position I am really sorry, my English is poor. I mean that the pause screen indicates the lost of signal,which shows picture and word is the problem I want to solve, rather than the black picture.
Well,I am back,dealing with this old topic.Because I never found a useful script.Anyone can help?
