Joined: 12/13/2020(UTC) Posts: 5   Location: Littleton Was thanked: 1 time(s) in 1 post(s)
Quick question about bundles and virtual sets. It seems that virtual sets do not get saved with Bundles (all virtual sets load as dummy inputs and say they are offline); this also happens when someone loads a vMix preset made from someone else; and the dialog pops up to locate all the missing files; all files are able to be re-located except for virtual sets (maybe because they are folders?); and then again they show as offline once the load process has finished.
This did not happen in vMix24; Virtual Sets were able to be located, as each missing file window popped up for the missing assets.
Originally Posted by: avkills  Quick question about bundles and virtual sets. It seems that virtual sets do not get saved with Bundles (all virtual sets load as dummy inputs and say they are offline); this also happens when someone loads a vMix preset made from someone else; and the dialog pops up to locate all the missing files; all files are able to be re-located except for virtual sets (maybe because they are folders?); and then again they show as offline once the load process has finished.
see https://forums.vmix.com/...-25-Changelog#post100670
