SHORTCUT to ACTIVATE/DESACTIVATE the CHROMAKEY
Joined: 2/3/2021(UTC) Posts: 2  Location: California Thanks: 1 times
How to create a shortcut to ACTIVATE or DESACTIVATE the CHROMAKEY checkbox when using an input (Like camera )
We are using 3 cameras. My camera #2 is used for the real set (as the 2 others) but also for the chromakey. I would like to facilitate the switching between no chromakey and chromakey on. My operator has little time to open the menu and click on the box to unable the chromakey and press the #2 option to activate the chromakey. I would like to have a shortcut to do that automatically using our X-Key hardware.
How to achieve that?
Thanks!
Not possible
Alternatively create a virtual input of it so you have one with and one without the chroma key and switch between the two with a shortcut
