DAK313
#1 Posted : Tuesday, March 15, 2022 7:31:39 AM(UTC)
DAK313
New to vMix but not production software in general. My client has a house audio system. The goal is/was to bring in a remote guest and have them questioned by a host while broadcasting the video through a house projector and the audio back through there system. I took their "audio out" to my ProFX6 USB mixer. Added that as a source in vMix. Added my vMix Call, but needed a way to get the audio from the vMix call back out through the same system I was getting their audio in. I tried taking the "Headphone Out" audio and running that back through their system but the vMix call was getting a bad echo then. It seems like I am missing some sort of mix minus. Any help or advice would be appreciated. Thanks!
mavik
#2 Posted : Wednesday, March 16, 2022 4:32:36 AM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
Add the caller to a Bus and in output settings you select the usb mixer as the output. Thus you get the caller onto the mixer and into their PA.
mtone
#3 Posted : Wednesday, March 16, 2022 12:54:45 PM(UTC)
mtone
make sure the output from the house audio being sent to vMix doesnt include the callers audio also.. if there is an AUX send on the house audio system you could connect that output to your ProFX6 and then only assign the interviewers mic to that AUX.. so the main outputs has both the interviewer and caller but the AUX only has the interviewer (which is being sent to vMix). this way the callers audio isnt being routed back to them from the house system..
