thecloudmediagroup
#1 Posted : Thursday, June 12, 2014 5:21:28 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
I noticed today that I have a small line of green on the top and the left of the video frame. It is small but noticeable. It happens on the recording regardless of the input.
My recording resolution is .TS 1080 59.94 or 29.97
My global resolution is the same
Color space is YUY2
Anyone else have this issue?
Maximus
#2 Posted : Thursday, June 12, 2014 8:17:00 PM(UTC)
Maximus
I haven't experienced that, but when I record at High HD using Cineform codec I get a green frame occurring randomly in the recording. I don't seem to get it at Medium HD. Martin suggest it might be related to my video card, so I plan to upgrade to see if it solves the issue. I don't know if my issue has anything in common with yours so I will see what turns up.
thecloudmediagroup
#3 Posted : Friday, June 13, 2014 2:23:08 AM(UTC)
thecloudmediagroup
Hmm. I am running a GTX 760 Superclocked which should be more than enough.
What codec does the .TS recording use in vMix?
#4 Posted: : Friday, June 13, 2014 3:29:16 AM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
Open up the recording in VLC and go to Video -> take a snapshot and email it to us
for further analysis.
#5 Posted : Friday, June 13, 2014 3:29:41 AM(UTC)
Or preferably, create a 10 second recording and send that!
#6 Posted : Friday, June 13, 2014 11:11:22 PM(UTC)
Ok, I have had a look at the recording.
A few questions:
1. Does it appear in all recordings, or has it only happened recently?
2. Does it show up if you record to another format such as AVI?
3. Have you tried changing the output format to UYVY and recording with that instead?
Thanks,
thecloudmediagroup
#7 Posted : Saturday, June 14, 2014 4:04:09 AM(UTC)
thecloudmediagroup
A few questions:
Thanks,
It seems to only have started recently maybe in the last few weeks or so.
Let me try recording to AVI and see.
I will also change the settings to UVYV and see if that does anything.
