newgeppetto
#1 Posted : Monday, March 14, 2022 3:47:33 AM(UTC)
newgeppetto
Italy
Hi All,
someone had try or know if it's possible to use key & Fill with Blackmagic 8K Pro)
xaver
#2 Posted : Monday, March 14, 2022 5:39:51 AM(UTC)
xaver
Rank:: Advanced Member
into vMix or out of vMix?
newgeppetto
#3 Posted : Monday, March 14, 2022 6:41:06 AM(UTC)
newgeppetto
Italy
Into vMix.
I know it's possible with Decklink Duo 2.
I'm thinking to buy a capture card, but if possible I prefer decklink 8K to have 4 input 4K.
xaver
#4 Posted : Monday, March 14, 2022 6:12:22 PM(UTC)
xaver
I think it should work, because key and fill are two inputs, which will be combined to the overlay
we have two decklinck Duo 2 in our vMix machine and (per mistake) get key and fill on two different cards without any problems
#5 Posted : Monday, March 14, 2022 10:14:14 PM(UTC)
Was thanked: 509 time(s) in 478 post(s)
@ newgeppetto
The DeckLink 8K Pro is not recommended for use with Key and Fill with vMix.
You may get it to work in some situations but it will likely come at the expense of the functionality of some of the other ports.
Essentially, the DeckLink 8K pro is not a true multi-channel capture device like the Duo or Quad, and its the "black magic" in the card that allows it to be as such, which doesn't quite translate to full functionality when trying to use it for Key and Fill.
newgeppetto
#6 Posted : Tuesday, March 15, 2022 2:18:22 AM(UTC)
newgeppetto
Italy
Thanks IceStream.
My Idea was to buy a card with 4K@60 input to use normally with watchout, but in this time to use with vMix ( Input and external output and the possibility to use them to generate Fill & Key for video mixer )
Paolo
