Hi It would be nice to add option to change all functions where vMix uses time from 12h to 24h system. I can't find option to cange production clock to 24h and it would be nice to have 24h default in counters.
Also in production clock there are some text that are black in dark gray backround and those are really hard to read. Is it possible to change text to white?
Joined: 12/27/2012(UTC) Posts: 5,526  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Tuomas  Hi It would be nice to add option to change all functions where vMix uses time from 12h to 24h system. More specifics pls like which ? Quote:I can't find option to cange production clock to 24h and it would be nice to have 24h default in counters. Counters do display in 24hr not ? using the HH:mm:ss format Clocks have a 24 hr selection (ok production clock only has AM/PM option) +1 on that one Quote:Also in production clock there are some text that are black in dark gray backround and those are really hard to read. Is it possible to change text to white? ? like with the invert option ?
I mean the production clock and the counter preset format. Yes you can change the counter, but it is one extra step that you have to do :-D And here. Maybe you could think other way to present that option is now awailable than to use black text.  black text.jpg (26kb) downloaded 1 time(s).
Originally Posted by: Tuomas  Yes you can change the counter, but it is one extra step that you have to do :-D hmm countdown here is standard at HH:.... Clock is the first choise . Don't see issue there If there is another format for the countdown to be first ( standard) one can always "edit" the user.config file ;-) Quote:And here. Maybe you could think other way to present that option is now awailable than to use black text.
hmm text not visible because option is not available just as it iss then not possible (greyed) to "edit" these settings associated with them. The (bug) error there is that the text "Hour offset" is still visible if not for clock ;-)  Screenshot 2022-03-13 192241.jpg (26kb) downloaded 1 time(s). Screenshot 2022-03-13 192205.jpg (25kb) downloaded 1 time(s).
