Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
25.0.0.24
* Fixed an issue with detecting missing files when opening a preset
 7 users thanked admin for this useful post.
25.0.0.27
* Fixed issue where turning on or off tabs like the replay tab may cause other tabbed windows to change position. * Vimeo and Restream have recently discontinued support for logging in via an in-app popup window, due to it using Internet Explorer. These have now been changed to use the computer's default browser instead. * Twitch login also changed to use computer's default browser, as we expect login via a popup window to no longer work there shortly as well.
25.0.0.29
* Fixed issue selecting replay camera angles when using exactly 8 cameras. * Fixed issue with Virtual Sets not saving in bundles * Fixed missing LiveLAN tab in Web Controller Titles page * Web Controller Switcher now supports R for replay, and N for NDI inputs. It will also show full input titles when hovering mouse over each button. * Fixed issue with replay controller window when opening a preset
 9 users thanked admin for this useful post.
25.0.0.31
* New Trigger Manager in hamburger menu to easily see all triggers in a preset. * Fixed replay audio issue with certain capture cards, particular Magewell Pro Capture. * vMix will now prompt to stop all outputs when opening a preset instead of just showing an error. * Virtual input will no longer save a duplicate file in a bundle. * Fix automatic audio mixing issues when switching between Replay A and B when both are set to run separately.
 18 users thanked admin for this useful post.
QuiapoChurch on 5/11/2022(UTC), jet on 5/11/2022(UTC), mgrayeb on 5/11/2022(UTC), STADIORADIO on 5/11/2022(UTC), doggy on 5/11/2022(UTC), Sandyjam on 5/11/2022(UTC), eduardocfs on 5/11/2022(UTC), dasmedienatelier on 5/11/2022(UTC), robertskiba on 5/11/2022(UTC), stigaard on 5/12/2022(UTC), DC Mike on 5/12/2022(UTC), dmwkr on 5/13/2022(UTC), raugert on 5/13/2022(UTC), Chircanu on 5/14/2022(UTC), nikosman88 on 5/14/2022(UTC), monamiga on 5/22/2022(UTC), vishwa.prakash on 5/23/2022(UTC), grantcoll on 9/5/2022(UTC)
25.0.0.32
* Fix for error when closing vMix with the latest v13 of Waves VST3 plugins * vMix now prompts to save existing preset when opening another preset. * Fix for using quotation marks in titles for YouTube Live Stream Now. * Fix for frame delay showing by mistake for VLC inputs as it is not supported.
 6 users thanked admin for this useful post.
25.0.0.33
* Fix for crash when exporting Replay MP4 when audio source is set to a camera with no audio * Incomplete replay events now automatically filtered out when exporting multiple events.
25.0.0.34
* Fixed audio static issue when using Resample audio drop handling with Dante inputs.
 13 users thanked admin for this useful post.
QuiapoChurch on 7/28/2022(UTC), ask on 7/28/2022(UTC), nikosman88 on 7/28/2022(UTC), monamiga on 7/28/2022(UTC), ON.tv Channels on 7/28/2022(UTC), bbbullock on 7/28/2022(UTC), raugert on 7/28/2022(UTC), eduardocfs on 7/29/2022(UTC), broadcastguy on 7/29/2022(UTC), Roi on 7/30/2022(UTC), sinc747 on 7/31/2022(UTC), tridenator on 8/20/2022(UTC), carmelo on 10/3/2022(UTC)
