SpaceAge
#1 Posted : Wednesday, March 9, 2022 3:48:45 AM(UTC)
SpaceAge
I am currently using a PTZOptics 30x camera with great results on a vMix system but I've recently come across the following camera:
https://www.bhphotovideo..._hdmi_3g_sdi_rs_232.html
It has very similar specs to the PTZOptics model at half the price. Has anyone used this camera before? Has it been tested with vMix? I've love to know if it can use one of the PTZ standard within vMix to control it and create virtual inputs.
paco3346
#2 Posted : Wednesday, March 9, 2022 7:22:17 AM(UTC)
paco3346
Was thanked: 35 time(s) in 32 post(s)
According to the spec sheet it does support the VISCA protocol, one of the many PTZ protocols that vMix supports.
Between NDI and SDI this camera will probably integrate nicely with vMix in almost every aspect. I don't have any experience with this brand though and can't comment on the quality.
SpaceAge
#3 Posted : Thursday, March 17, 2022 12:55:03 AM(UTC)
SpaceAge
Thanks. I've reached out to BZBGear and they are sending me a test unit. So I'll report back once I have tested it out.
SpaceAge
#4 Posted : Thursday, February 29, 2024 1:15:34 PM(UTC)
SpaceAge
I've been able to deploy a few BZBGear PTZ caemras in a few locations with vMix as the streaming software and it works great. I've used them with SDI and/or NDI with success.
