pm
#1 Posted : Tuesday, March 8, 2022 4:32:02 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Hi
I have two questions regarding GT titles.
Does someone know a workaround to clear a picture inside the title editor?
Currently it's only possible to change the path. I found a feature request on the subject. But I feel like I've overlooked something else.
How can I reset a GT title to the default state without removing and readding the title input itself?
My sitation is that one of my titles has a default picture assigned which is part of the gtzip file. During the show, several other pictures are loaded by api, which are not part of the gtzip file. At one point I want to go back to the default state with the default picture.
Thank you very much for your hints!
Patrick
MartLeib
#2 Posted : Tuesday, March 8, 2022 6:40:49 AM(UTC)
MartLeib
Estonia
1. Use an empty transparent PNG file if you need to "empty" image.
2. Create two presets for the title (using + button under browse) and select the second one on the list. When changing images it is the one that is updated, if you need to go back to "start" click on the first preset.
thanks 1 user thanked MartLeib for this useful post.
pm on 3/11/2022(UTC)
