richardgatarski
#1 Posted : Saturday, October 9, 2021 1:18:09 AM(UTC)
richardgatarski
Adding a Photos Input, selecting a folder (e.g. "Slides") results in an Input named "Slides".
Changing the name to, for example, "Pictures" works fine. But then trying to change it back to "Slides" is ignored and the name remains "Slides".
Not a big deal I guess, but it caused me some frustration and had to re-program some scripting when I ran into this issue.
Cheers,
/richard
richardgatarski
#2 Posted : Thursday, February 24, 2022 12:59:15 AM(UTC)
richardgatarski
awkward workaround: delete the name and it will revert back to the original text.
(hat tip to RichDanby)
MartLeib
#3 Posted : Thursday, February 24, 2022 1:20:25 AM(UTC)
MartLeib
Estonia
Just going to add that changing the name using API works as expected, bug exists in the UI only.
If you want to reset the name to default faster you can use a shortcut called SetInputName with an empty value and use "Hover" as input. Just another workaround to a simple bug..
