Joined: 2/16/2022(UTC) Posts: 4  Location: Kassel Thanks: 1 times
Dear All, In our normal use case we work a lot with multible layers in MultiView inputs. We mostly have to transmit at least 3 signals at the same time. So our request would be to have the possibility to switch the layer order in a multiview window including the associated positions, croppings and borders. Now we have to switch the inputs, get back in "Position of each layer and copy the numbers from one to the other. Alternativly it would be great to have a button that copies all the parameters under "Position" at the same time. So there could be a button next to the "Reset all" with "Copy all" and "paste all". I know there is the Multiview preset option but this always copies the whole MultiView setup with fixed layer orders, and is nor really helpful in this setup. Thank you very much! Achim  Copy and Paste.jpg (108kb) downloaded 0 time(s). Layer Switch.jpg (127kb) downloaded 2 time(s).
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
 2 users thanked richardgatarski for this useful post.
thank you for this. I didn’t know that this feature exists. Will try that out asap. This will probably be very helpful.
Joined: 4/4/2016(UTC) Posts: 235  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
+1 for Copying Values between layers inside the MultiView(layers).
