Hi I wanted to know if this card Blackmagic DeckLink Studio 2 works with Vmix if I understand you can capture and play simultaneously? Thank you
Joined: 5/18/2015(UTC) Posts: 150 Location: Australia
Thanks: 81 times Was thanked: 109 time(s) in 71 post(s)
The Decklink Studio 2 is mono-directional, either capture or playback. Most likely due the fact that the card is an A-D and D-A converter, with analogue, AES/EBU & embedded SDI sound options, plus composite, component YRB/YC and SDI video. It’s very similar to the Decklink Ultra-Studio Pro USB3 device in operation and function. A great playback card, as it provides all the possible solutions for analogue/digital audio and composite/component/SD-SDI/HD-SDI video environments. Plus HDMI capture and playback. A real all-rounder.
1 user thanked BETech for this useful post.
Joined: 3/7/2012(UTC) Posts: 2,603 Location: Canada Thanks: 33 times Was thanked: 501 time(s) in 470 post(s)
@ op music
Perhaps you are confusing it with the Decklink Duo or Duo 2... Which are capable of simultaneous IN and Out feeds.
Choose the Decklink SDI 4K...it can capture and play simultaneously.
1 user thanked csepi74 for this useful post.
