blis
#1 Posted : Wednesday, November 17, 2010 4:31:38 AM(UTC)
blis
Anyone notice audio selection going astray in the mixer or is it just me?
melody
#2 Posted : Wednesday, November 17, 2010 7:43:28 AM(UTC)
Rank: Guest
Groups: Guests
i had the same problem but already solved (for me)...
can you describe what configurations are you using? (pal, ntsc, audio card...)
#3 Posted : Wednesday, November 17, 2010 8:42:29 AM(UTC)
Was thanked: 4171 time(s) in 1498 post(s)
Can you describe what happens to the audio and when it occurs?
blis
#4 Posted : Wednesday, November 17, 2010 5:25:19 PM(UTC)
blis
Complete name : C:\Users\blis\Videos\Sequence 01_1.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 299 MiB
Duration : 5mn 11s
Overall bit rate : 8 052 Kbps
Encoded date : UTC 2010-11-13 22:20:52
Tagged date : UTC 2010-11-13 22:23:41
©TIM : 00:00:00:00
©TSC : 25
©TSZ : 1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.2
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 5mn 11s
Bit rate mode : Variable
Bit rate : 7 986 Kbps
Width : 1 024 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.542
Stream size : 297 MiB (99%)
Language : English
Encoded date : UTC 2010-11-13 22:23:36
Tagged date : UTC 2010-11-13 22:23:36
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 5mn 11s
Bit rate : 61.6 Kbps
Maximum bit rate : 108 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Stream size : 2.29 MiB (1%)
Language : English
When I load this file and others Ive made as mp4s as an input, the mixers shows audio signal but cant play it back. Captured source prior to "the cut" plays.
Im assuming it's a configuration problem at my end.
Name NVIDIA High Definition Audio
Manufacturer NVIDIA
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_10DE&DEV_0012&SUBSYS_10DE0101&REV_1001\5&1FE358EF&0&0001
Driver c:\windows\system32\drivers\nvhda64v.sys (1.0.15.0, 128.60 KB (131,688 bytes), 11/09/2010 11:32 AM)
Name High Definition Audio Device
Manufacturer Microsoft
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_1106&DEV_0397&SUBSYS_104383C4&REV_1000\4&90AEDE&0&0001
Driver c:\windows\system32\drivers\hdaudio.sys (6.1.7600.16385, 342.00 KB (350,208 bytes), 14/07/2009 10:07 AM)
melody
#5 Posted : Thursday, November 18, 2010 6:30:28 AM(UTC)
Rank: Guest
Groups: Guests
what value (fps) you here when that camera is on program?
