NDI
Can't Capture Vmix Output
Hi, I try to adding skype calls to vMix with return video and audio. When my skype PC added input 'Vmix Output' of MainPC Vmix using NDI,it just black screen/ won't display the thumbnail. Everything just fine when I added Skype PC Display1 to MainPC Vmix using NDI, but my Skype PC couldn't otherwise. I used this method : http://www.vmix.com/know...h-return-video-and-audioHow can I fix this issue? Thanks.
Joined: 8/2/2013(UTC) Posts: 1,033 Location: Fairhope, Alabama USA Thanks: 543 times Was thanked: 196 time(s) in 162 post(s)
On your Main PC in Settings --> External Output/NDI --> Is the box at Recording/External/Output checked? It should be.
- Tom
NDI
