How to start vMix with Fullscreen disable?
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Dear...
Is there anyway to start vMix with the Fullscreen disable? I don't have 2 monitors. Everytime I start vMix, its default is Fullscreen. I'd like to start vMix without Fullscreen activated, I can then activate (enable) Fullscreen feature when I need by mouse click on it.
Thank you for your help.
Michael.
Rank: Guest
Groups: Guests
hi msburg,
think is not possible (please correct me if it is possible). however, precise the finality why you want fullscreen disabled. I might be able to help you with another solution...
regards melody
melody wrote:hi msburg,
regards melody When I start vMix, it took control of the display. I cannot start another application until I turn off the FULLSCREEN mode. If I connect a second monitor, the second monitor goes blank (black) until I turn off the FULLSCREEN mode. I think vMix should have allow the user to select/set FULLSCREEN mode upon starting vMix through command line switch or through ini file. Thanks. Michael.
Rank: Guest
Groups: Guests
maybe you have some graphic card misfits. try to configure your graphic card correctly... what model of your graphic card by the way?
Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4171 time(s) in 1498 post(s)
This option will be available in the next version.
Martin vMix
Rank: Guest
Groups: Guests
hi martin, thats great...
apparently the new version of vmix promises to be more stable and efficient with the new changes. martin is working hard ... I'm waiting for the new version of vmix.
