Instant Replay
I can only select 1 Camera
Hi, I 'm new with Vmix , I took several days mulling over a problem.
I do not get activated more than 1 camera, instantly replay , I get the camera 1 to select between my camera , but the 2 3 and 4 off, 2 3 and 4 work perfectly in the live. Any solution , thanks.
Joined: 3/7/2012(UTC) Posts: 2,602 Location: Canada Thanks: 33 times Was thanked: 501 time(s) in 470 post(s)
@ Ken_Adams
I hate making assumptions, so maybe you can provide a few more details... What version of vMix are you using? Can you provide a screen shot of the 'Instant Replay' selection window and the issue you are having in choosing cameras?
Hello, have the same problem. Vmix ver 16 PRO Have add 2 cameras to input
i have the same problem, any solution??
Joined: 8/3/2015(UTC) Posts: 323 Location: Chicago, IL
I only have vMix 4K so I can only run 1 camera replays. But... I do have trouble changing the settings when there is a different replay profile (not sure the correct term) loaded from before. I have to delete the contents of my replay folder (the saved replay settings) before I can select certain options. Maybe that has something to do with it? Does it do this with a fresh replay input?
Groups: Joined: 10/17/2016(UTC) Posts: 6 Location: New Zealand
Hi all,
in the same boat with regards to only being able to select 1 camera.
Running two Intensity Pro cards. Can bring both in as a 'live source' but can only select one in IR.
Any advice.
Cheers.
Joined: 8/2/2013(UTC) Posts: 1,030 Location: Fairhope, Alabama USA Thanks: 542 times Was thanked: 194 time(s) in 160 post(s)
fundownunder wrote:in the same boat with regards to only being able to select 1 camera. What edition and version of vMix are you using? Edition = Pro? Version = 17.0.0.112? - Tom
Hi Tom,
vMix Pro 17.0.0.107
Joined: 10/13/2012(UTC) Posts: 1,161 Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
@Fundownunder... Try deleting everything in the Replay recording folder or specify a new location. Then restart vMix, add a IR input and see what you get. Have just tested here on three systems and all works fine.
Yep, what ask says for sure. Also, you should update to 17.0.0.112.
- Tom
Thanks sinc747 and ask for replying so quickly.
I'm still troubleshooting for what ask recommended didn't work for me.
Could it be because I'm not saving to a SSD? Maybe on this PC the graphics card is under spec'd. It's an AMD Radeon HD 7700 Series
That said I have another PC with a Nvidia GeForce GTX 960 graphics card with a Blackmagic Decklink Duo. I can see both live SDI sources but still only a single camera in IR.
Cheers
fundownunder wrote:Hi Tom,
vMix Pro 17.0.0.107 Can you post a screen shot of the top left hand corner of your screen? Regards. Andrew
the same problem in 24.0.0.51 deleting all do not work closing replay trying to create new replay restarting vmix restarting pc these all does not works.
Joined: 11/11/2016(UTC) Posts: 378 Location: Europe Thanks: 23 times Was thanked: 38 time(s) in 32 post(s)
do you have pro or 4k version?
it is 4k version cams are 1080@50p
it was working ok till yesterday
also have tried reinstalling declink desktop drivers reinstalling vmix
upd: installing trial solves the problem. very strange to get it stop working just before the live.
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 14 time(s) in 10 post(s)
The answer for this one is easy.
If you have a 4K licence and not a Pro you are limited to 1 angle.
If you were previously on a trial you were granted a temporary Pro licence. Upgrade to pro and your all good to go!
Instant Replay
