Instant Replay
vMix Replay multiple outputs
Joined: 8/5/2015(UTC) Posts: 49 Location: Germany Thanks: 11 times Was thanked: 3 time(s) in 3 post(s)
I'm trying to figure out, how to send recorded replay files individually to an hardware output (Decklink Quad 2) - instead of using the "replay A / B" Bus / Output.
I would like to be able to use this as a "pseudo"-live replay for training purposes. It would be great to send the recorded "live" feed back to my visionmixer (on individual channels) and to another PC where another vMix Replay is running.
New, unexperienced replay operators could be trained that way.
The 4 Output buses could work, but how do I get the recorder Camera 1-4 signals assigned to them?
Any ideas?
Thanks, Knut
Thanks: 62 times Was thanked: 119 time(s) in 108 post(s)
Export the recordings as very long replay events, use them as video inputs, assign them to the four outputs and add a shortcut to start the videos simultaneously.
1 user thanked dmwkr for this useful post.
Originally Posted by: dmwkr Export the recordings as very long replay events, use them as video inputs, assign them to the four outputs and add a shortcut to start the videos simultaneously. Now, I got it... My brain seems to need longer from time to time... I actually am fine with just the recorded vMix replay files, so I don't even need to export long events. So what I do now is: 1. import the needed replay files from the existing REPLAY folder to one vMix system 2. set the external outputs source to the inputs of those files 3. set the external outputs renderer to the appropriate SDI outputs and voila! Thanks again.
Instant Replay
