lestra
#1 Posted : Monday, April 1, 2024 11:34:33 PM(UTC)
lestra
Saint Kitts And Nevis
vMix v27.0.0.72 SRT wont work. Tried and checked everything but it stopped working. Can somebody help on this?
lestra
#2 Posted : Tuesday, April 2, 2024 2:41:18 AM(UTC)
lestra
I am using IRL Pro, it is free app build on Larix Broadcaster SDK. Sending srt cam from phone to OBS works but on vmix wont work on same settings.
#3 Posted : Tuesday, April 2, 2024 5:14:40 AM(UTC)
Was thanked: 922 time(s) in 761 post(s)
Can confirm that it works just fine be it on local network or remote
lestra
#4 Posted : Tuesday, April 2, 2024 6:24:35 AM(UTC)
lestra
Thanks! I tried
Samsung Note8 (don't work)
Samsung 10+ (don't work)
Samsung 21 Ultra (WORKS!)
Does it has something with android version?
#5 Posted : Tuesday, April 2, 2024 6:30:22 AM(UTC)
Thanks! I tried
Why don't you give us more information
H264 of HVEC?
Local or remote
caller, listerner or rendevous
other settings
if it phone model related why would it work in OBS and not vMix ?
"SRT wont work" isnt cutting it
lestra
#6 Posted : Tuesday, April 2, 2024 7:27:20 AM(UTC)
lestra
Ok I will try my best. After I changed ISP I can not do port forward any more with new router because my new ISP do not allow port forwarding on dynamic IP. So I installed OpenVPN on my dedicated server and use it on phones and PC. It works very well.
On phone there is IRL Pro installed and I use it in two ways.
1. Locally
2. Remote via OpenVPN
In both cases same results with all phones: Only S21U works on vMix.
In IRL Pro settings like this
srt://192.165.1.6:1002 for local connection without vpn, and
srt://10.8.0.3:1002 for remote (this IP is assigned as local address by OpenVPN)
PHONE set as CALLER
PC set as LISTENER
Latency 2500
Format is by default set to AUTO, but...if I set it to H264 every phone works, if it is on HEVC no one works. I think somehow AUTO on s21u know that it must be H264. Will check more and come back with update.
lestra
#7 Posted : Tuesday, April 2, 2024 1:57:38 PM(UTC)
lestra
Yes, SRT/HEVC don't work on vMix.
#8 Posted : Tuesday, April 2, 2024 3:30:08 PM(UTC)
Yes it does. Your phone might not !!!
Might want to check the adaptive bitrate streaming mode within IRL pro. My older phone had To be set to legacy for example.
lestra
#9 Posted : Tuesday, April 2, 2024 4:40:58 PM(UTC)
lestra
Checked all, in my case only H264 works on older phones. Thanks for help Doggy.
