Joined: 8/8/2019(UTC) Posts: 24 Location: Georgia Was thanked: 2 time(s) in 2 post(s)
I have an MP3 music file (MyMusic.mp3) loaded in an audio input (IntroMusic) controlled by scripting. I need to find the runtime of the file before it is played. It should be in a Xaml read but I can't sort out the code to extract it.
Thanks in advance
Joined: 11/23/2020(UTC) Posts: 154 Location: Wichita Thanks: 9 times Was thanked: 21 time(s) in 17 post(s)
This MP3 player script I wrote checks the length of the MP3 in it's "playing" loop. Note that the length is in milliseconds. You really should ask questions like this in the " Scripting For Dummies" thread here, it's a great resource for finding scripts and learning how to make them work. Code:
'Script to be triggered by a Keypadkey or X-Key to start playing an MP3 as background audio
' When you add a new MP3 player, you need to add it's key to this array
Dim PlayerKeys() as String = {"86fecea6-0bec-43b2-8989-4c548973b94f","a8bac9b2-0898-46ad-87b8-ef668d1f3147","0b59d4f0-a95d-4bbf-b6f5-3259045d8955","32fbcbd5-a1ff-4222-ac16-319c88b1d596","da73d4fd-0713-482b-966a-bd871c89f7a7","5700a5c0-a78d-4e7a-8848-23f11f4bcd34","c31f2b8b-0768-4e76-a0ab-f6668f1078a0","4c20abe9-e44b-4caa-8ab6-918bdb4704b3","bef6d0f0-466b-4129-a168-f0cf8ac107a0","e9b292c9-aa6a-4fb2-81e1-8f699c130ab1","85939ecf-941a-4ab1-b205-77b8d716cf8a","c93de854-7bad-457e-9cbb-544aa4017a86","8007b0ad-6fcf-4c88-9421-3411a94dcf37","f5981acd-c41b-42f7-b44f-060bb8d7bce8"}
Dim vMixState as new system.xml.xmldocument
vMixState.LoadXML(API.XML)
Dim PlayerNumber as integer = 0 ' This is the only line that needs to be changed to change the player number, note it's zero based here and one based in the names
Dim PlayerKey as string = PlayerKeys(PlayerNumber) ' Get the Key for our player from the XML
Dim PlayerTitle as string = vMixState.SelectSingleNode("//input[@key='" & PlayerKeys(PlayerNumber) & "']/@title").Value ' Get the Title for our Player
' ----------- Check to make sure no MP3 player is currently running before we start another one ----------------------
Dim PlayerIndex as integer
Dim OKToPlay = true
For PlayerIndex = 0 to PlayerKeys.Length - 1
Dim state as string = vMixState.SelectSingleNode("//input[@key='" & PlayerKeys(PlayerIndex) & "']/@state").Value
if state = "Running"
console.writeline(vMixState.SelectSingleNode("//input[@key='" & PlayerKeys(PlayerIndex) & "']/@title").Value & " is currently running, " & PlayerTitle & " cannot be started")
OKToPlay = false
'Else
' console.writeline("Player number " & CStr(PlayerIndex + 1) & " is not running")
end if
Next
If OKToPlay ' I would have liked to just quit executing in the above For statement if another player is running but there's no Quit statement implementation here so we have to use a honking big IF instead to bypass the functional code
Dim MP3Player as Object = Input.Find(PlayerTitle) ' Should use the Key but it's BROKEN!!!!! so we have to use the Title instead
console.writeline(PlayerTitle & " is now starting " & PlayerKey)
' Configure Input to match requirements in case this is a newly added MP3 player - only needed once but doesn't hurt to change again
MP3Player.Function("AutoPauseOff") ' Don't pause if someone sets this as "live" and then switches away from it, shouldn't happen but let's be safe
MP3Player.Function("AutoPlayOff") ' Likewise don't start playing it if someone switches it "live"
MP3Player.Function("AutoRestartOff") ' And don't restart it automatically either -- essentially we turn off the automatic actions
MP3Player.Function("LoopOff") ' We are setting these to only play once, may need another script for repeat plays
MP3Player.Function("AudioBusOff","M") ' Audio doesn't go to the master bus, it will get fed to the master through the local sound board
MP3Player.Function("AudioBusOn","A") ' Audio goes to BUS A which feeds to our local sound board
' Now to set the MP3 to play
MP3Player.Function("Restart") ' Make sure we play from the start
MP3Player.Function("AudioOn") ' Turn on audio for this input
MP3Player.Function("Play") ' Start the MP3 playing (finally!)
console.writeline ( PlayerTitle & " should be playing")
Dim MP3IsPlaying as boolean = true
Do While MP3IsPlaying ' Now we loop until the MP3 finishes playing
sleep(1000) ' Start the loop by waiting 1 seecond (1000 milliseconds)
vMixState.loadxml( API.XML() ) ' Load that XML into a document tree
Dim Duration as string = vMixState.SelectSingleNode("//input[@key='" & PlayerKey & "']/@duration").Value ' Find the "Duration" of the MP3 (in milliseconds)
Dim Position as string = vMixState.SelectSingleNode("//input[@key='" & PlayerKey & "']/@position").Value ' Find the current playing point of the MP3 (in millseconds)
'console.writeline("Duration=" & Duration & " Position=" & Position)
If Duration = Position ' If the position is the same as the duration then it's finished playing
MP3IsPlaying = false
end if
Loop
console.writeline(PlayerTitle & " finished playing")
MP3Player.Function("AudioOff") ' Done so turn off the audio for this input
console.writeline("Audio reset after " & PlayerTitle & " finished, script terminating")
end if
I stumbled on a solution that seems to work"
' Given an Audio Input loaded with an MP3 file titled IntroHymn ' iMusicPlayTime is the runtime in seconds
dim iMusicPlayTime as integer dim xml as string=API.XML() dim x as new system.xml.xmldocument x.loadxml(xml) iMusicPlayTime = CInt(x.SelectSingleNode("//input[@title='IntroHymn']/@duration").Value)\1000
