Joined: 9/3/2020(UTC) Posts: 15 Location: British Columbia
I would love to be able to batch load video inputs. Just pick a starting number input and multi-select the import files and voila!
Joined: 12/27/2012(UTC) Posts: 5,092 Location: Belgium Thanks: 284 times Was thanked: 921 time(s) in 760 post(s)
Originally Posted by: huggybear I would love to be able to batch load video inputs. Just pick a starting number input and multi-select the import files and voila! How about selecting mutiple videofiles (file explorer) and drag to the vMix Gui ?
Originally Posted by: doggy Originally Posted by: huggybear I would love to be able to batch load video inputs. Just pick a starting number input and multi-select the import files and voila! How about selecting mutiple videofiles (file explorer) and drag to the vMix Gui ? Well, that does sort of work. The problem is it automatically puts it on the end of the inputs. So, I have to then manually drag it to the input number I want. Takes about the same amount of time either way. Was hoping I could assign the starting input number than batch load beginning at that number. Thanks for the reply, JT
