A lot of freezes on camera inputs
Joined: 4/4/2020(UTC) Posts: 16 Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hello.
I need your advice.
I have a problem with vMix update from 25 to 26 or 27 versions.
A little about my PC with vMix software:
OS: Windows 10 with latest update
vMix: 25
Motherboard: ROG STRIX X299-E GAMING II
CPU: I9 10980XE
RAM: 32 Gb
GCard: NVIDIA RTX A4000 (latest driver).
Capture cards: 2 pc. Decklink Duo 2. 7 camera inputs (1080p50) and 1 output (1080p50)
In this configuration vMix work fine. I decided to update my vMix to 26 version (or 27) . When update was complete I loaded previous vmix preset, which worked perfect on 25 version of vmix, on 26 I have had a lot of freezes on camera inputs. After that I rollback vmix to ver.25 and all camera inputs work without freezes.
What can be wrong? What the difference between those versions?
Same issue here on the 27th version. All my input cameras Decklink are Freezing in this version all the time.
Joined: 11/14/2012(UTC) Posts: 259 Location: Finland Thanks: 107 times Was thanked: 15 time(s) in 13 post(s)
Originally Posted by: SerVag Hello.
I need your advice.
vMix: 25
CPU: I9 10980XE
RAM: 32 Gb
What can be wrong? What the difference between those versions? What version of the BMD Desktop Video do you have installed? 12.8.1?
Originally Posted by: Radio Tupi Same issue here on the 27th version. All my input cameras Decklink are Freezing in this version all the time. Please tell about your hardware. vMix Project settings etc!
Yes. BMD Desktop Video 12.8.1 vMix 27.0.0.69 MOBO: Z490 VISION G CPU: i7-10700F RAM: 16gb GPU: NVIDIA GeForce RTX 2060 Caputure: DeckLink 4K Extreme and DeckLink Quad 2 vMix 25 before working perfectly. No Freezing.
Yes. BMD Desktop Video 12.8.1 vMix 27.0.0.69 MOBO: Z490 VISION G CPU: i7-10700F RAM: 16gb GPU: NVIDIA GeForce RTX 2060 Caputure: DeckLink 4K Extreme and DeckLink Quad 2 vMix 25 before working perfectly. No Freezing. vMix Project settings? (resolution and frame rate? This info you can find from Settings/Display/->Master Frame Rate and Output Size)
vmix project settings is 1080p50. BMD Desktop Video - 12.8.1
