Feature Requests
New triggers - audio on / audio off
Joined: 1/23/2022(UTC) Posts: 69 Location: Milton Keynes Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
For situations where a separate sound operator is controlling the audio mixer panel, or even a midi mixer controlling whether an input's audio is live (on) or not, it would be great to have a trigger when this audio state is changed, regardless of what's happening with the video mix at the time.
Joined: 2/18/2014(UTC) Posts: 1,815 Location: Stockholm
Thanks: 138 times Was thanked: 292 time(s) in 246 post(s)
what would such a trigger do that cannot already be done via the shortcut/api that is changing the Input's audio state?
Originally Posted by: richardgatarski what would such a trigger do that cannot already be done via the shortcut/api that is changing the Input's audio state? If someone is using a mouse to control the audio mixer panel in vMix, clicking to turn on and off audio, then no API or shortcuts are involved.
Originally Posted by: spinfold For situations where a separate sound operator is controlling the audio mixer panel, or even a midi mixer controlling whether an input's audio is live (on) or not, it would be great to have a trigger when this audio state is changed, regardless of what's happening with the video mix at the time. I second this request. We have a situation when we can get broadcast audio from two different source depending on which volunteers show up. I have to program 4 shortcuts matched to two different buttons so that I can swap audio from one input to another. I would like to be able to create one shortcut to toggle the main audio on and off with a trigger that will change the state of the other audio input off or on. If Input 1 audio is on Input 2 audio is off and vice versa. We should have an option to have a trigger for audio state.
Feature Requests
