Jef Berard (QUB)
#1 Posted : Thursday, February 8, 2024 6:23:54 AM(UTC)
Jef Berard (QUB)
Canada
Hi!
With 8 vmix calls often used in addition to external equipment, recording and mixer, is it possible to increase the number of external audio outputs?
It happens that I have to have more than 2 vmix calls on the same output and that causes me problems on the air (eg: I have to speak to a speaker who has just connected while the other person is already on the air)
Thank You!
#2 Posted : Thursday, February 8, 2024 9:56:18 PM(UTC)
Was thanked: 501 time(s) in 470 post(s)
@ Jef Berard (QUB)
Do you mean a talk-back channel as explained in this video:
Jef Berard (QUB)
#3 Posted : Friday, February 9, 2024 5:01:42 AM(UTC)
Jef Berard (QUB)
Canada
Thanks but no, I already do that and it works well. :)
For exemple :
M = recording / streaming
A = to TV mixer
B to G = 6 outputs remaining for my 8 vmix calls or externals, it's too little for my needs.
(we are live on television and radio 12h a day, this requires preparation in advance without impacting the channels already used)
spinfold
#4 Posted : Friday, February 9, 2024 10:12:45 AM(UTC)
spinfold
For exemple :
A = to TV mixer
Why do you need a bus per caller?
vMix handles MixMinus internally so you don't need to worry about giving a dedicated bus to each caller unless there is something unique you're doing which requires each caller to have a separate audio feed?
While I agree that vmix needs more audio buses, you don't need to use it in the way it appears you are.
Jef Berard (QUB)
#5 Posted : Friday, February 9, 2024 12:26:02 PM(UTC)
Jef Berard (QUB)
Canada
We are a live channel with nearly 60 guests or columnists per day, so while an interview is in progress, sometimes the tv manager must communicate with a guest who connects to vmix call to test certain things without disturbing the interview in progress.
mtone
#6 Posted : Friday, February 9, 2024 7:05:25 PM(UTC)
mtone
its not the most elegant option but the busses are stereo you should be able to use two mono sources per buss.. which is 12 outputs..
spinfold
#7 Posted : Saturday, February 10, 2024 7:23:38 AM(UTC)
spinfold
Is there a reason you can't have a dedicated audio bus for your talkback microphone (say Bus B) and then switch the caller's audio source to Bus B on press, and back to Main on release, of a Streamdeck button?
