Feature Requests
Change Zoom participant source via shortcut/command/companion
Currently the only way to change a participant source is by right clicking on the input or via the zoom manager, right clicking a name.
Can this be accessible via a shortcut, TCP or any other method? We use companion, so it'd be great to be able to control it that way. It would replace us using Zoom OSC.
Thank you,
Joined: 1/23/2022(UTC) Posts: 72 Location: Milton Keynes Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Thank you, +1 This is definitely needed. Either an index number or just previous and next controls.
vMix has their names already from the SDK, so we could simply have Companion set to point to specific names. ZoomOSC has that function, as long as the name matches. You can disable "allow participants to rename themselves" and set their names as host. See ZoomOSC companion example: osc.png (10kb) downloaded 0 time(s).
+1
This is definitely needed - I was expecting a whole load of API stuff for Zoom in v27 but there is literally nothing.
vMix keeps the original names and doesn't update if a participant changes it, so don't even need to disable participant renames in Zoom.
What might be even better is a way in the Zoom Manager to assign numbers to certain participants - so you could preset your commands with "zoom assign 1", "zoom assign 2", "zoom assign 3", etc then choose in the manager which participant is assigned those numbers.
Joined: 2/7/2024(UTC) Posts: 23 Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Joined: 7/5/2019(UTC) Posts: 28 Location: Sydney Was thanked: 5 time(s) in 4 post(s)
Feature Requests
