Hardware Compatibility
Blackmagic Decklink Quad HDMI Recorder give massive delay after adding more than 2 source
Joined: 11/20/2023(UTC) Posts: 1 Location: Phnom Penh
I have been using this Quad HDMI Recorder card on our original PC setup for few years and we didnt have problem with delay at all until recently we got some profit and we bought new PC which is more powerful and wanna make it into main broadcast PC so we take the card from OLD PC to plug in NEW PC. When it all work fine and received feed as normal until we start adding more than 1 Source in Vmix from the same card it give us at least 2sc delay from the feed. Here our Example:
*OLD PC: -Slot 1 : PC HDMI -Slot 2 : PC HDMI -Slot 3 : Camera HDMI -Slot 4 : PC HDMI
Spec : RAM : 32GB GPU : RTX 3060 CPU : Core i7-11700K MOBO : TUF GAMING Z590-PLUS WIFI
*New PC: -Slot 1 : PC HDMI -Slot 2 : PC HDMI Just this 2 already give the delay.
Spec: RAM : 32GB GPU : RTX 3080 CPU : Core i7-12700KF MOBO : B660 GAMING X DDR 4
I wanna mention that all the cable and PC are all the same we been using it for years just this new PC that start giving problem.
Thanks: 62 times Was thanked: 119 time(s) in 108 post(s)
Watch Tim's Video on PCIE slots, especially the chapters about slots and lanes: And then check the expansion slot specs of your board: https://www.gigabyte.com...G-X-AX-DDR4-rev-10/sp#spIt says, the 2nd and 3rd PCIE slots are only running at x1 speed, so, unfortunately, they are too slow for the capture card.
