BrixxNatt
#1 Posted : Sunday, November 12, 2023 3:52:45 AM(UTC)
BrixxNatt
Germany
There is a problem playing XAML , please check , as the xaml titles are not working properly , it is reversed , in and out ..
please check .
#2 Posted : Sunday, November 12, 2023 4:36:45 AM(UTC)
Was thanked: 922 time(s) in 761 post(s)
please check .
Which one(s) , custom or vMix's ?
Might want to read on the update release notes (post #44)
* Migrated vMix and related apps to .NET Framework 4.8!
This should result in performance improvements across the board and allow installing on Windows 10 and 11 without requiring the older .NET Framework to be installed.
Custom XAML may not work any longer, as it was officially deprecated in vMix 24
BrixxNatt
#3 Posted : Sunday, November 12, 2023 5:08:32 AM(UTC)
BrixxNatt
Germany
Even Legacy XAML
#4 Posted : Sunday, November 12, 2023 5:38:30 AM(UTC)
Even Legacy XAML
I did a check
V27 def does reverse the animiations ( example AnimatedInOutHD.xaml)
The same title plays differently (same exact code) in v27 compared to previous vMix versions
Something is amiss in how v27 interprets the storyboards (can switch the code within the 2 storyboars to correct this, not the storyboard numbers)
So far no issues with my custom xaml (.dll) titles . hope it stays this way as it can do things one can just NOT achieve at all with GT titles !!!!!! XAML based titles def have their use still within vMix (part of its power)
