jas105
#1 Posted : Tuesday, October 31, 2023 2:30:30 PM(UTC)
jas105
Hi all,
Does anyone know how to change the speed of a ticker? At default it is at a very slow pace and I would like it to be a little faster.
Secondly, is there a way to loop the text? Meaning if my last word is "...yellow." and first word is "There...", it will look like "...yellow. There..." instead of "yellow._________(space here)__________There...".
Just want to cut that space out. Hopefully that made sense. Thanks
kross
#2 Posted : Tuesday, October 31, 2023 3:17:23 PM(UTC)
kross
Was thanked: 28 time(s) in 28 post(s)
To change the speed, right click the input. Select title editor. Then in the title bar, click the clock icon. You can change the speed there.
As for the other issue, I don't think there is a way. You will probably need to put in a feature request.
thanks 1 user thanked kross for this useful post.
jas105 on 11/3/2023(UTC)
#3 Posted : Tuesday, October 31, 2023 6:12:06 PM(UTC)
Was thanked: 922 time(s) in 761 post(s)
Originally Posted by: jas105 Go to Quoted Post
Hi all,
create a csv file with the same text in 2 rows , add a space to one of the rows of text (so both rows are different in content)
Set datasource to "Auto Next"and "loop"
link the ticker to the datasource and set its type to "add"
play wiht the speed setting of the ticker and the autonext speed of the datasource to get the spacing to your liking
