Systems
system for replay only
Joined: 10/20/2023(UTC) Posts: 32 Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
hi everyone, i'm looking to set up a pc replay for 8 x 1080p50 cams, at low cost no broadcasts, no overlays, just monitoring replay for referee there will be 32gb DDR4 ram and 2 x ssd m.2 4 x 4.0 (1 for windows and 1 for record) but how to determine which other cpu / gpu components will suffice? i find vmix recommendations quite high if any of you are already using a dedicated 8 cams HD replay system or other, what is your config and what percentage is used by cpu and gpu in vmix? thanks
Systems
