Beta Discussion
Shortcut to Toggle ISO vs Mixed Audio in Zoom? [RESOLVED]
Joined: 3/23/2020(UTC) Posts: 135 Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
A shortcut to toggle between ISO and MIXED audio on a Zoom input would be super helpful.
Thanks for adding that option so quickly.
Greg
Joined: 1/13/2010(UTC) Posts: 5,163 Location: Gold Coast, Australia Was thanked: 4176 time(s) in 1499 post(s)
Can you describe a use case of where you would need to toggle this in the middle of a show?
Originally Posted by: admin Can you describe a use case of where you would need to toggle this in the middle of a show? Actually in thinking this through - no I can't. Really we need to have just one input allocated to mixed audio that can be solo'd or made live if needed. The existing audio shortcuts should suffice for that. But TBH I would prefer to have the mixed audio available as an AUDIO ONLY input. We generally don't need video with the mixed audio unless there is something like an active speaker pin. I would prefer not to have to tap into the available video bandwidth just to bring in the mixed audio. I'd like to save that 30mbps for maximum usable ISO video pins. Thank you. Greg
We could look into that, however it sounds like the ideal workflow is just to have a separate Zoom input for the Mix input and keep that so you can easily switch to it when needed.
The video feed won't impact the performance very much if it is in use on another input already.
Originally Posted by: admin We could look into that, however it sounds like the ideal workflow is just to have a separate Zoom input for the Mix input and keep that so you can easily switch to it when needed.
The video feed won't impact the performance very much if it is in use on another input already. Hah! Yes I was actually re-writing my entire post to say exactly that just as you replied. So please see my revision above. But it would be useful to have the mixed audio as an audio only input. Generally don't need video on it. Thank you. Greg
Beta Discussion
