Beta Discussion
PFL , change S Symbol to PFT
Joined: 1/25/2019(UTC) Posts: 287 Thanks: 16 times Was thanked: 73 time(s) in 54 post(s)
Is this the right place for this? i hope so. the pfl function is great, but would it be possible to change the green S (SOLO) button to PFL or P and in another color. after a week i can't remember which audio channel was set to PFL.
Originally Posted by: Peter1000 Is this the right place for this? i hope so. the pfl function is great, but would it be possible to change the green S (SOLO) button to PFL or P and in another color. after a week i can't remember which audio channel was set to PFL. Great idea. Very frendly use.
Thanks: 10 times Was thanked: 32 time(s) in 27 post(s)
I would suggest not only to indicate PFL. Because for me it's not PFL on or off, it's a decision between AFL and PFL.
So the solo button should show "AFL"/"A"/"SA" (or similar) or "PFL"/"P"/"SP" (or similar).
1 user thanked pm for this useful post.
Beta Discussion
