vMix Call
Vmix Call / OBS desktop Audio
I am running a show whereby the "host" is remote. The issue I'm running into is when i want to switch to his OBS, which i bring in via Vmix call (Virtual Webcam), or SRT, for gameplay or anything that is running on his PC i can hear myself coming over his vmix call. that is because OBS is picking up the entirety of his desktop audio.
Is there a fast and easy way to solve this? I'm open to all suggestions (for my own knowledge) but in reality I can't make a lot of changes if any at all on his computer such as installing new software and things like that.
Thanks for any help anyone can give on this!
Joined: 4/23/2017(UTC) Posts: 1,155 Location: Germany Thanks: 3 times Was thanked: 167 time(s) in 149 post(s)
I could see a way with vmix running on both sides. The basic HD 60$ would be sufficient. Then you have the call(up to 1080) within vMix, are able to add the screen capture as a source there directly and you can use the buses and different audio outputs so that no loop is happening. Another way is to use a mobile phone with headset for the call. a third option, if he sends via SRT and you use mobile phones for comms. There are intercom or pushToTalk apps available for free
Joined: 12/24/2021(UTC) Posts: 364 Location: athens Thanks: 113 times Was thanked: 54 time(s) in 51 post(s)
Try to use virtual cables app. See this video for reference on how to do it
vMix Call
