GT
Ticker bug with adjustable background
Joined: 10/19/2022(UTC) Posts: 2 Location: copenhagen
Hi there
Is it possible to make a rectangle box that adapts after the lenght of the text? I have at ticker that have the bottom direction. I put a colored box behind the ticker-textlayer and I would like to make the box autosize as text expand or shrink.
Thomas
Joined: 12/27/2012(UTC) Posts: 5,095 Location: Belgium Thanks: 284 times Was thanked: 922 time(s) in 761 post(s)
Thomas
You can have a colored box adapt to the length of a text . A ticker doesn't know how long a text is as it "scrolls" through the box. Trying to change the box size for a ticker seems to me to contradict the ticker concept DO you have a visual example of your intentions?
Thomas
You can have a colored box adapt to the length of a text . A ticker doesn't know how long a text is as it "scrolls" through the box. Trying to change the box size for a ticker seems to me to contradict the ticker concept DO you have a visual example of your intentions? Hi Doggy I have two layer. One with the tickertextbox. Isnt it possible to use autotextbox resize when the text is comming from top or bottom in a ticker? Here is an exampel. If the text gets wider, is it not possible to make the tickertextbox wider automatical? Sequence 01.gif (963kb) downloaded 8 time(s).
GT
