T68
#1 Posted : Friday, February 17, 2023 7:24:43 PM(UTC)
T68
Sweden
Everything worked fine but suddenly I get an error message when pressing rec in instant replay.
Replay Recording Start Stop.ReplayInput_ConfigureSources Camera 1: Output 2 size must match Replay Session Format. Source: 1280x720 Replay: 1920x1080
I think I have everything set to 1280*720 but apparently somewhere it's been changed to 1920*1080. Just cannot figure out where.
I am a vmix greenhorn.
Thanks in advance for any input on this!
#2 Posted : Friday, February 17, 2023 9:15:17 PM(UTC)
Was thanked: 501 time(s) in 470 post(s)
@ T68
Double check your Instant Replay session settings as it would appear it is set to 1920x1080.
(perhaps to accommodate cameras as all sources must have the same resolution)
https://www.vmix.com/hel.../SystemRequirements.html
TL68
#3 Posted : Monday, February 20, 2023 8:57:16 PM(UTC)
TL68
Sweden
Problem solved by creating a new replay session.
Weird though since the existing session did not show the resolution box but an error message. Failed to take a screenshot but it said somethin about session being created with an earlier version of vmix. Strange since I have been on same version since first install.
well, well. Glad I got it sorted!
