NTSC
#1 Posted : Monday, October 31, 2022 6:18:09 AM(UTC)
NTSC
Has anyone been able to successfully use a Rodecaster Pro II and vmix and bring in the various channels separately so I can an assign each one a Vmix input?
I basically want to do what vmix outlines in this support doc with my 2.
I have multiple Mics and audio set up in the Rodcaster Pro II and I want to place them each in their own input on vMix so I can better control the audio flow.
In vmix I was expecting to add audio input, choose Microphone (Rodecaster Pro II Main) and the below it choose the drop down menu you choose which audio device I wanted on that input. (like is shown in the above support page)
Alas, there is no way to select the individual input.
Thanks.
roverradio
#2 Posted : Friday, November 11, 2022 7:27:26 AM(UTC)
roverradio
Do you have ASIO driver installed? And have you activated USB multitrack on the Rodecaster itself?
https://rode.com/en-us/u...ding-and-exporting-audio should get you going (about 2/3 of way down on the page)
ptnrs
#3 Posted : Thursday, February 23, 2023 2:35:27 AM(UTC)
ptnrs
Hello to both of you,
NTSC have you achieved it ?
I have a brand new RCP2 and trying to use the ASIO driver brings me the error ASIO,BASS_ERROR_ALREADY if i try to add an audio input.
Setting the RCP2 ASIO output also prevents VMix for starting (silent crashing on splash screen).
ASIO drivers are here and other ASIO enabled device (Livetrak L-8) is working well.
ptnrs
#4 Posted : Friday, March 17, 2023 1:43:01 AM(UTC)
ptnrs
Has anyone made the RCP2 work with vMix ?
Support only ask me to check connections and processes, yet the same device, in the same conditions, works perfectly in OBS with obs-asio plugin.
So i am pretty sure it is a problem specific to vMix.
vMix is useless to me if i can't use the RCP2.
